Modifying text dimensions
Hello, if try to modify a text dimension appear a text that say "to modify the value related to lenght or angle of a segment, select the element of which is refferd to, so click on the value to modify this".
What can I do to have the result?
Thank's
martijn_pater
Are you trying to adjust the angle or overwrite the value, if the latter... why? You can overwrite the text input by right clicking and changing the value type (unicode text to US ie.) For changing font etc. edit the dimension type.
Ps. consider carefully to use these kinds of overwrites.
@martijn_pater  overwrite the value.
Doesn't give  me possibility to do change text.
martijn_pater
Right-click value field, look for unicode input. See above (edited) post. You can overwrite text this way.
@martijn_pater  can do a screenshot please?
Do not undrestand
MostafaElashmawy
What @martijn_pater mentioned is correct.
Below screen shot for reference.
Mostafa Elashmawy
