how cam I change the intersection wall?
The orizontal is in the core and connect to the other core.
I would the orizontal wall at internal finishing of vertical one.
Thank's
Gelöst! Gehe zur Lösung
Gelöst von martijn_pater. Gehe zur Lösung
You can select the wall, right click blue dot and select disallow join. Drag to face. Or you can set function in the wall type to determine how the wall layers join. First one is easiest for now, but try to figure out the other method for later I suppose. Useful to understand.
Have a look there to adjust the wall layer priority.
@martijn_pater "right click blue dot and select disallow join. Drag to face." is ok but so have to do to all the wall, one by one.
With other method don't know.
In a wall at least one layer have to stay in the core. So I don't know how to solve in the other way.
Ah for multiple walls, well you could set a lower priority to the adjoining wall's layer funtion (see link above)... and/or higher priorities for the orange wall's layers in the wall type, ie set all to structure. That should do it.
Edit:actually maybe move those within wall core boundary.
