MODIFYING MULTIPLE CURTAIN WALL GRID
HELLO REVIT COMUNITY,
IS THERE A WAY TO MODIFY MULTIPLE CURTAIN WALL FAMILY GRIDS?
MostafaElashmawy
What do you mean by modifying them?
moving them? adding new? changing profile?
for moving the grid, select it, unpin it then move it.
to add new grid, use curtain grid tool in architectural tab
Mostafa Elashmawy
You can create different Curtain Wall Family TYPES, each with a distinctive Vertical/Horizontal Grid Pattern.
ennujozlagam
as long as you didn't put your curtain grid manually, then you can edit through edit type in the properties just click your curtain wall. thanks
