How to edit color scheme value/title)
marcbartolucci
marcbartolucci
I made a color scheme for floor finishes. Is there a way to edit the the Value column that I use to name them (see image). Basically I am looking to rename it and I cant seem to figure out how.
MostafaElashmawy
make a room schedule, sort by floor finish , now you can rename it.
Mostafa Elashmawy
Color schemes pull information from actual Room's parameter. Open room schedule, add FLOOR FINISH field, sort by it, untick Itemize every instance, then you can rename the value.
marcbartolucci
Hey it sort of worked, the problem however is that it didnt actually rename it, it created a new category (and also assigned a new color), so it totally mixed up all of the colors on the plan...
Yes that is how it works. You have to reassign the color to the new value in the color scheme. I normally snap a screenshot so that I know the color numbers before I change the value.
marcbartolucci
oh i see.. Thanks
