Modifying Curtainwall - Storefront semi circle
BIM_Dreamer
Message 1 of 12
BIM_Dreamer
Hi, is there any way possible that, can I make semi circle curtain wall/storefront (with mullions) instead of segmented? thanks
Replies (11)
Message 2 of 12
If you want true curved mullions then one option is using in-place sweeps, another is using adaptive components, or simply a window family.
Message 3 of 12
BIM_Dreamer
thank you for your reply. are you kind enough to show me in video on how to do it.your help is much appreciated.
Message 4 of 12
planner_matlabi
Watch Screen Cast
If it solves your problem, feel free to click Accept Solution.
Message 5 of 12
BIM_Dreamer
great. thanks
Message 6 of 12
BIM_Dreamer
hi, how can delete those extra panel, i tried but i cannot delete. thank you
Message 7 of 12
planner_matlabi
Your Welcom
Message 8 of 12
planner_matlabi
Must Draw Continues By Main entrance lobby
Message 9 of 12
BIM_Dreamer
thnak you, i cannot do that because of the different profile circle line of the lobby, if semicirle can. is there any other way to delete those extra panel?. i attached the profile of the lobby for curtain wall. maybe you could help me to create a curtain wall with that profile. thank you
Message 10 of 12
BIM_Dreamer
@planner_matlabiplease ignore the first one i post. i attached the profile with door and the spacing for vertical mullion is 2m c/c. hope you could help me again. thanks
Message 11 of 12
BIM_Dreamer
here is the drawings change units to mm. thanks
Message 12 of 12
planner_matlabi
Hi
Excuse me for the delay in answering
I tried on your File
I hope your problem is solved
