Modify Linework: Blue dots don't show up
6 REPLIES 6
2305 Views, 6 Replies
When I am in an elevation (or section/plan for that matter), and go to the modify linework action, I will click on a line that I want to be modified, but the blue dots that control the segment of that line to be changed do not show up. So the entire line is changed to a thicker line without my control of having it shortened or not. Please help me figure out how to change this setting to allow the visibility of those blue dots.
6 REPLIES 6
Convert Line (see contextual tab)
in reply to: barthbradley
Thanks, Barth for you reply.  However, these aren't model nor detail lines, I am trying to modify the edge of a fin wall in an elevation. Also, I am in R2016 if that makes a difference.
Not Linework?  What is it?
It's the edge of a wall in elevation. I am trying to make my elevations have lineweights that help show depth in 2D. Yesterday, I was able to create these thick lines via "modify: linework" command (See attached: linework), and I was able to use the "blue dots" at the end of the lines that allow me to shorten the overridden edge (See attached: linework 2).  Today, those blue dots no longer show up when I go through the same process (See attached: linework 1).
I figured it out! I was in a current workset that was "hidden" in V/G for that view template. All I needed to do was switch my current workset to one that is visible!!! Thanks for you help & time though, Barth.
Corsten.Au
1. If the element is in section ( cut view ) then the LW ( line work ) wont show blue dot to edit .
2. If the element is in Projection line ( ex elevation ) only then the LW ( Linework ) will allow
you to modify / control the LW using those dots..
Have a go...
Corsten
Building Designer
