Please help me, options on the ribbon suddenly are not showing correctly, I didn't change any settings.
Title renamed for clarity: How to fix options on the ribbon that are not showing correctly?
Gelöst! Gehe zur Lösung
Gelöst von HermanSolomon. Gehe zur Lösung
Hi behdadyahyavi,
This typically occurs when one performs a double click on one of the ribbon icons. Should you continue to double-click on one of the icons, you will expand/contract the ribbon further. You can also use the icon to the far right of the ribbon to cycle through the different representations of your ribbon, as indicated by the image below.
Don''t worry, thats the normal behavior of Revit ribbon..
user interface design..
its there to maximize work area for pro users...just like in any auto desk program,
you can get rid of command panels and just use shortcuts...
but as everyone suggesting, just keep clicking it till you get back to default ribbon setting..
Hi @Anonymous
Did the recommendations by the experts help with your issue?
Let me know if you have additional questions.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
