10:11 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm reading this argument but do not undrestand the differences between the three opstion:
- Export category properties BYLAYER and overrides BYENTITY. A Revit LT element with view-specific graphic overrides will retain those overrides in the CAD application, but will reside on the same CAD layer as other entities in the same Revit LT category.
- Export all properties BYLAYER, but do not export overrides. View-specific graphic overrides will be ignored in the CAD application. Any exported Revit LT element will reside on the same CAD layer as other entities in the same Revit LT category. By forcing all entities to display the visual properties defined by their layer, this option results in a lower number of layers and provides by-layer control over the exported DWG/DWF file.
- Export all properties BYLAYER, and create new layers for overrides. A Revit LT element with view-specific graphics will be placed on its own CAD layer. This option provides by-layer control over the exported DWG/DXF file, and preserves graphical intent. However, it increases the number of layers in the exported DWG file.
How is "View-specific graphic overrides"?
Thanks'
