modify conduit fitting size
dfbolivara
dfbolivara
Is there a way to modify a conduit fitting size or minimum radious of bend? I need to connect the two conduits marked in red in the image but because of the size of the fittings it doesnt allow me to do it in the space i need and it goes wider.
I also tried modifying the minimum bend radius for the diameter im using but it keeps doing the same no matter the number i type.
Thanks a lot in advance.
SteveKStafford
Try using the Conduit Without Fittings conduit type(s). They usually allow for sweeps that specific fitting families do not.
Steve Stafford
handjonathan
Hi @dfbolivara
Thanks a lot for posting your question to the forums!   Has the solution suggested by @SteveKStafford helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
