There is a blank row below the title. I can manually add text, but I can delete the row. How do I delete it?
Solved by alan.johnson7YLND. Go to Solution.
Thanks, but that's not it. I know about that check box. I should have mentioned that.
If you have created rows in the title bar manually, then you can also delete them by clicking inside the row and pressing the delete button.
@DJHarrisEA6RG wrote:There is a blank row below the title. I can manually add text, but I can delete the row. How do I delete it?
Post a screenshot showing this "blank row" you are referring to.
