Modelling walls to be stripped to studs
- Mute
- Permalink
- Report
I'm working on a renovation to a summer house that will now be a year-round residence in Nova Scotia (ie cold-weather climate). The house was built in the 1970s so the existing insulation is the pits.
As near as I can tell (we haven't done any investigative work yet), I believe the exterior walls are:
- 2x4 wood studs with insulation in the cavity
- sheathing
- weather barrier
- wood shingles
In order to improve the building's thermal performance, the client wants to strip off the shingles and weather and add continuous insulation before re-installing new shingling over top. I'm preparing a demo and proposed floor plan but I'm not sure what the best way to model it is. I've considered the following:
- Leave the existing walls in place and create a new wall type that is basically continuous insulation + new shingles and wrap that wall type around the existing. I suspect this will create all sorts of problems when it comes to modelling around the window openings. It doesn't allow me to get rid of the existing shingles in the demo plan or proposed plan without doing linework overrides. Yuck.
- Set the existing walls as demo'ed in the demo plan and then in the proposed plan put in new walls that are essentially the same except with the continuous insulation. This is probably the most straightforward in terms of modelling but I'm concerned it will be very misleading to the contractor to show the whole wall assembly as demolished.
Is there a way to show just one wall component to be removed and then add new components in a new phase or is there at least some more straightforward workaround?
What's the best way to model this for both a demolition plan and proposed floor plan? I want the existing building components
