When I open 2 window of Revit 2020, the cursor starts flickering between normal cursor and the Windows loading cursor. Anyone have this problem?
id try making sure you have nothing else running..
also... is your mouse wireless.?? mine will act strange when the battery is low...
also... is your system up to par to run revit???
Processes running in the background can cause this too. Check to see what is running in the background through the Task Manager. End the process if it is interfering. You might also what to turn off some of the Startup processes.
It only happen when I open 2nd copy of Revit on the same computer. I linked my plans to master sets that set up for each project with 3-5 different floor plans. This way I have same master for all plans just link plan I want. I have multiple screens so I can open plan on one and master plan on the other, easy to update. This is why I need to open 2 Revit. Just update all drivers via HP Assistant.
We have Revit 2012 running on Windows 7 Pro and we never had anything like this. I am running Revit 2020 trial version on Window 10 pro. We want to make sure that we will not have any problems to go forward with 2020 on Windows 10.
i was having that happen a couple of weeks ago... i checked the task manager, and it appeared that nothing was running... made no sense... i shut down the computer and restarted... that seemed to solve the problem.
I opened task manager and found 1 program the was running and used very high power usage, once I ended that program, the problem went away. Thanks everyone for your help.
