Modelling Units in Multi Unit Building
BigBeam
BigBeam
I have a 40 unit townhome development with 10 different unit styles. The units are split up over 6 buildings and the 6 buildings all sit on shared underground parking. Each unit has 3 levels (ground, 2nd and roof balcony). Every building has a different arrangement of units types. The site is sloping so every building is at a different elevation.
I tried putting a unit in a separate Revit file with ground floor at EL 0'-0" and building up from there. I then tried LINKING the unit into my parking structure master model but the problem I ran into is I couldn't find a way to map the ground floor of my unit plan to the building ground floor elevation (ie. +50'-0" for the first building). Unless I am doing something wrong, this seems like a massive short coming with Revit.
For my 2nd try, I made a GROUP out of the unit (in the unit file) and then pasted the group into the master model but its not clear to me how the floor elevations get handled (no extra levels were added to my model, at least that I am aware of).  Once I get inside the unit, all I care about is floor elevations RELATIVE to the ground floor of each building  (10ft,20ft,30ft) on the parkade. Furthermore, I need to be able to change the relative floor elevations within a group and have this change propagate through the entire model.
Link the Multi-Level Unit into your "Master" Project, move it to where it belongs in relationship to the Master's modeled elements/coordinate system, and then, once positioned correctly, Publish Coordinates to the Link and SAVE.  Sounds like you may be missing the "SAVE" part.  Additionally, I would suggest copying the Link Levels to the Master via  Copy/Monitor on the Collaborate Tab.
BigBeam
But I have a type A unit that is referenced in 6 buildings pods but each building has a different ground floor elevation. If I understand you correctly, I don't think I should be pushing the floor elevations in my master model back into the link because an A unit has 6 possible ground floor elevations
Open the section in the master file and and move the 6 building pods vertically so that they locate at the 6 correct elevations.  You can still copy monitor each ground level of the 6 building pods to the master file and rename them accordingly.
So, you are saying that you have several instances of the SAME Link placed at different locations within the Master's Coordinate System; correct?  If so, do what I told you to do via the Link Instance's Shared Site Dialog Box and assign each Link Instance to its own unique Site Name.  Save and close Master, open the Link and go to Site Tab under Location and Site. There you will see all the unique Site Names published from the Master. Each Site has a different Survey Point Location.  Select each Site Name, make it Current, and watch what happens to the Survey Point.
For more information about this workflow, start with these two links:
Help | Defining Named Positions | Autodesk
Help | Move a Link Instance to a Named Position | Autodesk
