Revit 2021 - Poor Printing quality of PDF using Vector and 300 DPI
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
tturnerJBN46
296 Aufrufe, 4 Antworten
Poor Printing quality of PDF using Vector and 300 DPI. I tried changing it to 600 DPI. No change. I also though maybe the Floor was causing issues since they are embedded at the Top of the Floor. Attached is a Snapshot of the Model & the PDF. PDFs are printed using PDF-XChange Lite.
4 ANTWORTEN 4
Nachricht 2 von 5
RSomppi
als Antwort auf: tturnerJBN46
Are you seeing this only when zoomed in?
It's hard to see any difference between the two snapshots because you have thin Lines turned on in Revit.
Nachricht 3 von 5
tturnerJBN46
als Antwort auf: RSomppi
The Blue Boxes are not filling in in the PDF.
Nachricht 4 von 5
RSomppi
That discrepancy can be seen in the model, also. It's model elements that are interfering with the fill.
Nachricht 5 von 5
tturnerJBN46
Yes you are correct. Thanks. One of those days.
