Modeling a swoopy-curvy support
Sahay_R
Mentor Mentor
Message 1 of 9
Sahay_R
I am in the process of creating a family for this -
The seat was straightforward enough. I have modeled the angled support as an adaptive component - only to discover that it won't play nicely with my Specialty Equipment family. Any way that this can be accomplished, so that I can retain the ability to have 3 different size types in the family?
Thank you!
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Replies (8)
Message 2 of 9
Wanna cheat?
Message 3 of 9
There are many similar families from almost all manufacturers.
Message 4 of 9
Sahay_R
@barthbradley WHAT? Are you trying to tell me that all I needed to do was talk nicely to you to let down your family business? Smiley Very Happy
@ToanDN - point conceded. I see that in the family @barthbradley was kind enough to find for me, they had put the swoopy-curvy part together the hard way. However, I would still like to  know how to do this - and enhance my skills with adaptive components.
Rina Sahay
Message 5 of 9
Not sure if the adaptive approach is necessary. The geometry is quite simple. Generally, if the family is static or can be dimension based, there is no need for using adaptive.
Message 6 of 9
SteveKStafford
My instinct for the bracket is to create a host form (visibility off) and sweep a continuous path along its perimeter edge so it isn't necessary to make separate sweeps. The example image is an oversimplification but the essence is there. If the underlying form is constrained effectively the sweep will adjust accordingly if its size must vary.
Steve Stafford
Message 7 of 9
Sahay_R
@SteveKStafford - thank you - that is the approach that I will play with, instead of the two angled plates I have supporting my unfortunate bench in the family.....
Rina Sahay
Message 8 of 9
SteveKStafford
Well, the family provided by @barthbradley is the fastest path to get'r done, but for a try new things moment...glad to help.
Steve Stafford
Message 9 of 9
Actually, you can use the family I provided as a guide to build your own. Reverse-engineer it, and rebuild a "Rina" seat -- another fine product from The Sahay Corporation. Smiley Wink
