Void Sweep don't follow the visibility parameter correctly
2 ANTWORTEN 2
Nachricht 1 von 3
m.pharamawy
467 Aufrufe, 2 Antworten
I am attaching a family has two extrusions each one of them has it's own void sweep (to make a groove), now the problem is i am setting a visibility parameter to show and hide them with there sweeps, but one sweep is keep showing regardless of the visibility of it's extrusion. i don't know why, and the void sweep does not have a visibility parameter to adjust, however the other sweep is acting correctly..
in the yellow type, everything goes correct, in the red and pink types, the problem is shown
as shown in the pics, the red arrow points to the wrong sweep visibility
the green one points to the correct sweep vis.
noting that i am activating the visibility preview to test the family..
please help, many thanks in advance..
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: m.pharamawy
Your family contains only 1 void and 1 solid. What is the issue? I don't see any.
Nachricht 3 von 3
@m.pharamawy
You cannot assign a visibility parameter to voids. You however, can assign a length parameter to change their size to cut or not cut the solids. Optionally you then can assign a yes/no parameter to drive said length parameter: if ( cut, 100 mm, 1 mm). translation: if parameter Cut is true then make the void 100 mm to cut the solid; if not, make it 1 mm so it does not touch the solid.
