Model Text Prints Jagged
5 REPLIES 5
1609 Views, 5 Replies
This is with the surface pattern overridden to black.
5 REPLIES 5
This is with no override. It is still very jagged, when it appears smooth in Revit.
What's the Font?
in reply to: barthbradley
it's called gunplay. It does the same thing with Arial.
cbcarch
When printing, try adjusting settings to Vector or Raster with Presentation quality.
In the View, under Visual Style>Graphic Display Options, check "Smooth Lines with Anti-aliasing".
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
syman2000
What PDF driver are you using? Also what scale is your drawing?
Forma Design Contest
