Model Patterns
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
2183 Aufrufe, 5 Antworten
Model Patterns
I am trying to edit my .pat file (which I have done successfully in the past), but am having issues. The first few times I tried it, it wasn't showing the new pattern I created. Now it just says: No "Model" type patterns found. I hadn't fully created the pattern yet, as I usually do a bit of trial and error because I haven't totally figured out how to create patterns, but now I have nothing. The pattern I was creating is this:
*Tile 15x30 Ashlar, 15 x 30 tiles ashlar offset
;%TYPE=MODEL
0, 0, 0, 15, 0, 0, 0
90, 0, 0, 15, 30, 15, 15
I want the final product to look like the attached. I have also attached my file.
Thanks!
5 ANTWORTEN 5
Nachricht 2 von 6
PrathapSekar
als Antwort auf: Anonymous
Hi @Anonymous,
             You need to study the method of pattern creation to achieve your pattern which is in image you attached. The error is only because you had enter the value 15 in the position of shift instead of offset, and the last two digits are to represent the line pattern, if you need to maintain your line as solid then leave it as empty, no need to enter 0. For your reference I attached the updated pattern below.
;%TYPE=MODEL
0, 0, 0, 0, 15
All the best.
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
Nachricht 3 von 6
als Antwort auf: PrathapSekar
thanks very much. i'm trying to learn more about creating patterns, but I haven't necessarily found something that clearly articulates it in a way that I can reproduce the product. thanks!
Nachricht 4 von 6
I spoke too soon, there was an object covering the line in the view I was looking at. what I have now, based on what you gave me, is a stacked bond of 15x30. it doesn't offset like my image. is there a way to do that?
Nachricht 5 von 6
David_W_Koch
Assuming that you really want the pattern you showed in your image, and that that pattern repeats in a tiled manner, the following will give that to you:
*Tile_15x30_Ashlar, 15 x 30 tiles ashlar offset
;%TYPE=MODEL
0,   0,0,  0,45
0,  30,15, 0,90, 60,-60
0,  90,30, 0,90, 90,-30
0,  60,60, 0,90, 90,-30
0,  30,75, 0,90, 60,-60
90,  0,0,  0,30
Your pattern includes some 30x30 tiles, which are not offset in a consistent manner, hence the tiling of the pattern you showed.  If you do not want them to be tiled, then you are going to have to show a larger image that shows what the repeat is, and indicates whether or not some of the 15x30 tiles shown at the boundary of your previous image are part of a 30x30 tile.
The image below shows the pattern above.  The area outlined in the dashed, transparent red rectangle represents one tile of the pattern.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Nachricht 6 von 6
als Antwort auf: David_W_Koch
Thank you, that was it!
