Model Objects not printing or exporting
I have a sheet with 4 interior elevations. Up until today, all have printed without a problem. All of the sudden, the model objects in one of the views is not printing. I read up on changing the print settings to Raster instead of Vector, and that works for PDF output, however, those objects are not exporting (to CAD) either. I can "solve" the problem for PDF printing, but clearly those objects have some issue. I haven't made any changed to that view, yet all of the sudden it's not functioning properly.
Any thoughts? TIA.
ennujozlagam
hi, have you try to duplicate view and use that view to print. thanks
you may check it here.
Click HERE
I did, and that worked, but I'd still like to know why this is happening and if there is a way to prevent it, or if it's just an annoying fluke in the program. It's a solution, but not an ideal one. I'd like to avoid this happening at all. (Especially if it's happening as you're printing the final set, and notice that the drawing isn't there, when it all seemed fine on screen.)
that's less asking you specifically, and more just ranting...
