Model Line vs Symbolic Line in family
1 REPLY 1
so3tech_sur
530 Views, 1 Reply
The loadable family of passenger shelter was created and rectangle symbol should be generated to represent the size of shelter for plan production.
I would like to know “Model Line” or “Symbolic Line” is better to be adopted for creating the 2D symbol in my situation??
Symbol could be created by both types of Line in Plan View, but I need to turn the visibility off for the Model Line in 3D/Elevation Views. The pros and cons if I choose Symbolic Line?
Thanks.
1 REPLY 1
se.ha
in reply to: so3tech_sur
Hi @so3tech_sur,
do you want/need to see the lines in 3D/Elevations/Sections?
No - Symbolic Lines
Yes - Model Lines
That's about it for pros and cons.
se.ha
Dieser Beitrag war hilfreich? Dann könnt ihr diesen Beitrag gerne liken.
Hat dieser Beitrag die Frage erfolgreich beantwortet? Dann klickt bitte auf den Button 'Lösung akzeptieren'.
Forma Design Contest
