Model in Place with Revit LT?
BillAllenSE
Message 1 of 12
BillAllenSE
Can I do this in LT? I can only find "Place a Component".
TIA
Replies (11)
Message 2 of 12
mauricio_mssf
This is not a function of REVIT LT, for that you would have to upgrade to a full version.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Message 3 of 12
BillAllenSE
Thank you.
Message 4 of 12
nmarcelis
@BillAllenSE
You can check with features each flavour of Revit has on this page.
https://www.autodesk.eu/compare/compare-features/revit-vs-revit-lt
If this helped you please accept this as a solution
Revit Certified Professional Architecture, Structure and MEP.
Message 5 of 12
"Place a Component" is not "Model In Place". You can definitely Place a Component in LT.
Understand that the workaround to Model In Place is to Model a Family in a Family Template and load it into the Project.
Message 6 of 12
nmarcelis
@barthbradley
This is technically not OPs question
But you are correct, a workaround is to simply create a family.
Message 7 of 12
BillAllenSE
That's not a workaround for a sweep.
Thank you anyway.
Message 8 of 12
@nmarcelis wrote:
@barthbradley
So, basically what you are saying is that I'm wrong AND right. Would you say I'm more right than wrong? Or, am I more wrong than right?  Or, am I equally right and wrong?
Just being silly.  Cheers.
Message 9 of 12
BillAllenSE
Yes!
Thank you.
Message 10 of 12
Message 11 of 12
ejkearney22879
It a bummer you cant model in place, but I guess it has to have it's limitations.  Making you own family instead of model in place is something I will definitely try.
Message 12 of 12
kimmy3aa
Community Visitor
Community Visitor
🤕that hurt my brain...I still don't know if you're right or not
