Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Model in Place with Revit LT?
BillAllenSE
Message 1 of 12
BillAllenSE
Can I do this in LT? I can only find "Place a Component".
TIA
Replies (11)
Message 2 of 12
mauricio_mssf
This is not a function of REVIT LT, for that you would have to upgrade to a full version.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Message 3 of 12
BillAllenSE
Thank you.
Message 4 of 12
nmarcelis
@BillAllenSE
You can check with features each flavour of Revit has on this page.
https://www.autodesk.eu/compare/compare-features/revit-vs-revit-lt
If this helped you please accept this as a solution
Revit Certified Professional Architecture, Structure and MEP.
Message 5 of 12
"Place a Component" is not "Model In Place". You can definitely Place a Component in LT.
Understand that the workaround to Model In Place is to Model a Family in a Family Template and load it into the Project.
Message 6 of 12
nmarcelis
@barthbradley
This is technically not OPs question
But you are correct, a workaround is to simply create a family.
Message 7 of 12
BillAllenSE
That's not a workaround for a sweep.
Thank you anyway.
Message 8 of 12
@nmarcelis wrote:
@barthbradley
So, basically what you are saying is that I'm wrong AND right. Would you say I'm more right than wrong? Or, am I more wrong than right?  Or, am I equally right and wrong?
Just being silly.  Cheers.
Message 9 of 12
BillAllenSE
Yes!
Thank you.
Message 10 of 12
Message 11 of 12
ejkearney22879
It a bummer you cant model in place, but I guess it has to have it's limitations.  Making you own family instead of model in place is something I will definitely try.
Message 12 of 12
kimmy3aa
Community Visitor
Community Visitor
🤕that hurt my brain...I still don't know if you're right or not
