Model In Place Error
Message 1 of 8
I am getting some strange results when using a model in place.
I have used the pick 3D lines tool to select the ridge of my roof. I have then modeled ridge tiles using a sketched profile. This all works well until I confirm the in place model and the ridge tiles randomly shrink. Prior to this they would also rotate, unsure why I decided to delete them and do it again but now i'm running into this error.
Replies (7)
Message 2 of 8
Can you post a screenshot that shows the Profile in sketch mode?
Message 3 of 8
sure thing Brad.
for some reason every image I try to upload to Autodesk forums isn't working so I've had to upload it to a free image host; https://ibb.co/D5DjrTG
Message 4 of 8
edit: BB code didn't work
Message 5 of 8
That's it? You don't also have a void in the in-place component? That's what it looks like from here.  Look like you are cutting the sweep extrusion at intervals.
Message 6 of 8
I have no idea why but I made some minor adjustments to a dormer opening in the same roof and it made everything fall into place as it should.
very strange!
https://ibb.co/gjM0QzN
Message 7 of 8
So, it was a fluke. It's corrected now?
Message 8 of 8
seems to be yes, thank you anyway Brad
