Collaborating thru a VPN
1 ANTWORT 1
Nachricht 1 von 2
1028 Aufrufe, 1 Antwort
Hello, we are trying to collaborate thru a VPN, but for some reason Revit does not allow the remote user to create a local file on his own computer, even after being able to access the shared files from the VPN. Is there anything we should configure inside Revit, that can allow us to successfully collaborate with a VPN? Thanks. Ana
1 ANTWORT 1
Nachricht 2 von 2
sash.kazeminejad
als Antwort auf: Anonymous
Is the Crete New Local Grayed out? If so, it is more than likely due to a differnce in how the user is accessing the central model vs how it is actually saved on the network. This article will help guide you through this process, if this is actually your issue:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
FYI.....I would avoid collaborating through a VPN. Too slow. I would really look at BIM360 and C4R to accomplish this task.
Sash
