Model in Place Component (void)
ewFR43G
ewFR43G
I need to model a recess that cuts into a slab and RC beam. I have created my recess by going to Architecture tab > component > model in-place > floors > void forms. This works fine for the slab but when i come to cut the same recess into the beam it will not cut.
I have tried doing he same thing using 'structural farming' instead of floors to see if this will work for the beam but it is not cutting. any ideas please? thanks!
vitorbortoncello
Model the beam as in place component
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
mari.shimode
Hi @ewFR43G, did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future.
If you still have the issue, please let us know. Thank you.
Mari Shimode
