Tag with Elevation from Level
TravisClemons
TravisClemons
I'm wanting to add a label that will also list the "Elevation from Level" so when tagging a lateral brace, our site team can easily see how far above FF the element is. Currently, we use a standard tag in tandem with the standard elevation tag. This is cumbersome due to the numerous overlapping elements, making it easy to miss.
  • tags
Basam.Yousif
I understand you're asking if the 'structural framing tag' can have a new param for the elevation (from the level) of the highest point of the bracing?
I doubt that is possible in OOTB Revit. I'm sure Dynamo could, or some fancy API. You might also find 'Adsk Point Layout' to be useful for such case.
mari.shimode
Hi @TravisClemons, did you find the information provided useful? If so, please use Accept Solution so that others may find this in the future. Thank you.
Mari Shimode
