Model-in-Place component convert to Family component
Message 1 of 45
Is it possible to convert a Model-in-Place component to a regular Family component?
Example: I created a model-in-place of a retail fixture but would like it to be a standard component that I can load into other projects.
Accepted solutions (4)
Replies (44)
Message 41 of 45
mishaylab
Does anyone know if this process actually helps downsize the Revit file the Model-in-Place element was originally created in after it has been saved as a Family component?
Message 42 of 45
FacebookGroupMember
I tried this and Revit started saving out all families in the file. Anyone else have this issue?
Source Message URL: https://forums.autodesk.com/t5/revit-architecture-forum/model-in-place-component-convert-to-family-c...
Message 43 of 45
PeterChrien
Very interesting solution.
Message 44 of 45
luke.johnson
For future reference the live version of this post is at Save an In-Place Family as an RFA for use in another project » What Revit Wants (wrw.is)
Luke Johnson
Message 45 of 45
Sahay_R
Another option - edit the in-place geometry.
In the editing view, select and CTRL-C to copy, CTRL-V to paste the geometry in a blank family template of the correct category. Dimension and constrain as needed.
I've found this approach to be much simpler than the previous one, FYI.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
