- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everyone,
I've made myself a custom model hatch for Revit. I finally got the pattern itself right, but for some bizarre reason, the numbers I've input in seemed to have hardlocked into inches. All of what supposed to be 10mm joints are showing up as 254mm joints on the actual Revit workspace, which obviously looks ridiculous.
Is there any way for the Notepad file to recognize the coordinate numbers as mm? I'd rather have a solution that does not require literally dividing each number by 25.4 - although that may have to be a last resort if there is absolutely no other way.
Your answers will be much appreciated.
Hisashi
EDIT: For some strange reason, I can't seem to upload my attached files. ("The attachment's australian brick stretcher bond.pat content type (application/octet-stream) does not match its file extension and has been removed.")
I've attached a Google link if anyone wants to download, as I can't upload the files at all:
PAT file: https://drive.google.com/file/d/1YtXL0f0yR_IkajQ4q2bZ-wAx-y5byGRV/view?usp=sharing
My custom template file: https://drive.google.com/file/d/1pMEkZhKhuRCfhsgP8zoYS__EFUDy-ySw/view?usp=sharing
