Model complex roof structure with skylight in Revit
I'm an architecture student doing my BA and I'm wondering if anyone could explain or refer me to a step by step guide of how one would go about modeling the roof in the file I've attached!
Any help is appreciated!
Best regards
hi there,
create a mass (which at the end you will turn of from visibility settings) with the shape of the roof.
then use the roof by face option and select each face of the mass.
let me know if you can use this.
loboarch
Another option besides massing to try might be to use shape editing tools. You can create a flat roof with a hole in it and then use shape editing to get the different slopes.
http://help.autodesk.com/view/RVT/2020/ENU/?guid=GUID-A393B74D-CB81-4A44-B965-BBD329770B14
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Modify Sub Elements
Thank you this worked like a charm!
