Model chimney
Model chimney
glkirk
Message 1 of 8
Model chimney
glkirk
Good morning,
Could anyone help me find an easy way to model a Fireplace chimney?
Here, I have just made a thick brick wall but cant seem to make the ends show brick. Override graphics will not allow me to use Model patterns....
I tried Model in place Extrusion with no success.
Replies (7)
Message 2 of 8
Use Walls.
What version on you on.  Revit has Vertical, Tapered and Slanted Walls now.  If yours does not, try using Roof tool. There are other ways as well.  Shape-Editing the Wall Profile is one.  Walls by Mass Face is another.
Message 3 of 8
Maybe I misunderstood. Did you try Painting the blank Face. Just curious to know if that works. Shouldn't need to do it though.  Post the file here and we'll take a look and see.
Message 4 of 8
glkirk
I.m using 24. I did start out using just 4" walls and did fin a "Slanted" tool, but did not have much in the way of success. Corners did not join well.
I think I am shape-Editing the wall but the sides (Cuts will not become model pattern
Message 5 of 8
glkirk
The file (434 Carolina Ave.rvt) exceeds the maximum file size. The maximum file size is 71 MB.
This is the error message I get............
Message 6 of 8
Walls, Roofs and Paint Edges.
...and Attach Top/Base tool to attach Walls to Roof.
Message 7 of 8
glkirk
Yes, that will work by changing the roof to brick. (I now understand)
But instead, I worked with "masses" but was not happy.
Ended up understanding slanted walls. Had to make them only 1/4" and invisible some lines, but works for my "Existing presentation"
Thanks!
Message 8 of 8
handjonathan
Hi @glkirk Glad to see you got it all sorted.
Jonathan Hand
Technical Marketing Manager | Construction
