Cut plane not working
dillon_mulligan
dillon_mulligan
Community Visitor
Community Visitor
hello i am working on a project where i must show pipework. as i change the view range the pipework does not show even if its between the top plane and bottom plane.
the only way i can see the pipework is if the pipe intersects the cut plane.
could someone assist with this issue please ?
Change View Discipline.  Set View Detail Level to Medium or Fine as well.
handjonathan
Hi @dillon_mulligan
Thanks a lot for posting your question to the forums!   Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
