Message 1 of 21
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is it possible to sweep in revit based on an imported 3d design string from autocad?
@Gerald.Lockardhello, yes you can use sweep or extrusion. It's better to use family (rfa) to create your design, you can load and edit family for any changes. thanks
Thanks for the reply. I have tried this but as you can see in the attached screenshot, when I sweep and select the imported acad line revit appears it move it onto a plane.
It isn't picking up all the 3d geometry from the line.
Any ideas? Thanks
I have created 3d sweeps in acad in the past, but would like to do it in revit if possible.
I have the 3d strings for the sweeps, and the 2d cad profiles.
I can import 3d acad sweeps into revit and export to navis- but it's a bit messy having a mix of informatiojn for materials, mass, bim info etc
@Gerald.Lockard hello, you can use a generic model.rfa > go to 3D mode > sketch path. thanks
I have tried that but unfortunately it doesn't use the line, it looks like just projects one when i select it?
@Gerald.Lockard hello, share your file/post here? thanks
Here's the temporary file I created with a 3d line to test, thanks.
@Gerald.Lockard hello, your autocad file Z has a value you need to flatten and change Z value to 0, not sure if my interpretation is correct? please see attached. thanks
@ennujozlagam I think the point is that he needs to maintain the Z value of the imported line, not flattening it.
@Gerald.Lockard We would have thought it should be easier to re-use or trace 3d cad lines/plines/splines in Revit. Unfortunately they most likely need to be rebuilt. See screencast:
Here is a recent Facebook post from Autodesk Revit showing bringing in an SAT file or a bridge profile from Infraworks.
What a great commercial you got there, Jeff.
Like candy for kids, i'm buying it..
Thanks Toan,
I have been able to use the method you described to create a swept profile for the bridge barrier in 3d in revit, i'll test it to see if it works along longer more complex sweeps.
This video looks great Jeff, exciting to see the possibilities for future projects.
In this job we are working with imported 3d genio design strings, not an infraworks or c3d model.
https://revitbeyondbim.wordpress.com/2016/08/24/concrete-bridge-design-workflow/
the supposed workflow is this..
1. road and bridge design can be done using Infraworks
2. import in AutoCAD Civil 3D for further detailing of the ROAD design.
3. datareused in Revit by means of DYNAMO to get the detailed (!!??) bridge design.
4. rebar detailing and design documentation are further processed in Revit
Problem is , it is a 'one way' workflow.
what if it turns out some 'detail' of a bridge (eg construction height or pilar geometry) has an effect on the alignments that has to be 'tweaket'
..what do you do now ? Start all over at 1.? I don't think it is that realistic. You?
kind regards
hans
bridge designer
