Model A Bridge Deck
Model A Bridge Deck
Gerald.Lockard
Message 1 of 21
Model A Bridge Deck
Gerald.Lockard
Is it possible to sweep in revit based on an imported 3d design string from autocad?
Replies (20)
Message 2 of 21
ennujozlagam
@Gerald.Lockardhello, yes you can use sweep or extrusion. It's better to use family (rfa) to create your design, you can load and edit family for any changes. thanks
Message 3 of 21
hanslammerts
c3d corridor creation would be a better idea. After that, try using DWG solids in Revit
Message 4 of 21
Gerald.Lockard
Thanks for the reply. I have tried this but as you can see in the attached screenshot, when I sweep and select the imported acad line revit appears it move it onto a plane.
It isn't picking up all the 3d geometry from the line.
Any ideas? Thanks
Message 5 of 21
hanslammerts
Or as alternative, Try to Autodesk workflow. Use Inventors parametric engine to model bridge paets in combination with Infraworks (for alignments) After that, export it as IFC to Revit , and the detailling would be done in AutoCAD if i'm correct. Good luck on your journwy..
Message 6 of 21
Gerald.Lockard
I have created 3d sweeps in acad in the past, but would like to do it in revit if possible.
I have the 3d strings for the sweeps, and the 2d cad profiles.
Message 7 of 21
Gerald.Lockard
I can import 3d acad sweeps into revit and export to navis- but it's a bit messy having a mix of informatiojn for materials, mass, bim info etc
Message 8 of 21
hanslammerts
Stick to DWG and LEARN to model 3d. You might as well look at the abilities in ACA in combination with C3D.
Conversions.., well,.. They more or less s bigtime. 😉
Message 9 of 21
ennujozlagam
@Gerald.Lockard hello, you can use a generic model.rfa > go to 3D mode > sketch path. thanks
Message 10 of 21
Gerald.Lockard
I have tried that but unfortunately it doesn't use the line, it looks like just projects one when i select it?
Message 11 of 21
Can you share a sample cad file with a 3d spline?
Message 12 of 21
ennujozlagam
@Gerald.Lockard hello, share your file/post here? thanks
Message 13 of 21
Gerald.Lockard
Here's the temporary file I created with a 3d line to test, thanks.
Message 14 of 21
ennujozlagam
@Gerald.Lockard hello, your autocad file Z has a value you need to flatten and change Z value to 0, not sure if my interpretation is correct? please see attached. thanks
Message 15 of 21
@ennujozlagam  I think the point is that he needs to maintain the Z value of the imported line, not flattening it.
@Gerald.Lockard  We would have thought it should be easier to re-use or trace 3d cad lines/plines/splines in Revit.  Unfortunately they most likely need to be rebuilt.  See screencast:
Message 16 of 21
loboarch
Here is a recent Facebook post from Autodesk Revit showing bringing in an SAT file or a bridge profile from Infraworks.
"https://www.facebook.com/plugins/video.php?href=https%3A%2F%2Fwww.facebook.com%2FAutodeskRevit%2Fvid..."
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 17 of 21
hanslammerts
What a great commercial you got there, Jeff.
Like candy for kids, i'm buying it..
Message 18 of 21
Gerald.Lockard
Thanks Toan,
I have been able to use the method you described to create a swept profile for the bridge barrier in 3d in revit, i'll test it to see if it works along longer more complex sweeps.
Message 19 of 21
Gerald.Lockard
This video looks great Jeff, exciting to see the possibilities for future projects.
In this job we are working with imported 3d genio design strings, not an infraworks or c3d model.
Message 20 of 21
hanslammerts
https://revitbeyondbim.wordpress.com/2016/08/24/concrete-bridge-design-workflow/
the supposed workflow is this..
1. road and bridge design can be done using Infraworks
2. import in AutoCAD Civil 3D for further detailing of the ROAD design.
3. datareused in Revit by means of DYNAMO to get the detailed (!!??) bridge design.
4. rebar detailing and design documentation are further processed in Revit
Problem is , it is a 'one way' workflow.
what if it turns out some 'detail' of a bridge (eg construction height or pilar geometry) has an effect on the alignments that has to be 'tweaket'
..what do you do now ? Start all over at 1.? I don't think it is that realistic. You?
kind regards
hans
bridge designer
