Missing Transmit button when using etransmit revit 2018
namtran.archi
Observer Observer
Message 1 of 8
namtran.archi
Observer
Observer
I am using Etransmit of Revit 2018 and the transmit button doesn't show up. Can anyone help for this problem?screenshot.png
Replies (7)
Message 2 of 8
You need to select a Revit file eTransmit first.
Message 3 of 8
namtran.archi
Observer
Observer
I have tried and it still doesn't work.
Message 4 of 8
Have you tried to do it with the file open?
Message 5 of 8
I have the same problem!
Message 6 of 8
Same problem. etransmit button missing from etransmit dialog box in Revit 2020.
Message 7 of 8
syman2000
Looks like the bottom transmit model button is missing. You want to reinstall the plugin and install Windows Update.
Message 8 of 8
glenwalson7986
Check the screen Display resolution of your monitor. I've seen this happen when the Display resolution is set too high,
