downloaded families without material
I downloaded some Revit families but when I tried to render everything is white or grey. When I try to Edit type of the families, I can change the material. But nothing is changing when I am rendering again. What am I doing wrong? Please let me know. Thanks
aRcHiTeCt.JM
… hi @Anonymous
… do as follows:
… first try to edit type properties
… if you can’t change those
… go to materials
…. click in the material that you want to use and rename it (this step is critical to re-link the material to your model)
… and then reupload an image or material
…. or create a new one and apply it to the element you are using
…. go back to your model and render it again
…. done
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
thank you architect, I created some new materials and now is working
