missing properties and project browser box
Message 1 of 47
how can i open the project browser and properties box in revit 2013. they just disappeared. please help
Replies (46)
Message 21 of 47
I was having the same problem; the pallets I usually keep open weren't showing up when I opened my Revit project. I tried the suggestions indicated here and they didn't work for me. I use a separate monitor with an HDMI cable and when I switched the 'main display' from my monitor to my laptop screen in my computer's display settings, it fixed the problem--the browser pallets showed up in Revit.
Message 22 of 47
Thank you for your reply,
Is that mean I need to consider the second monitor as a main screen ?
Message 23 of 47
LIsa, Thank you for the short but perfect guide.
Message 24 of 47
thanks
Message 25 of 47
 I started in one multi-monitor scheme, moved to a different monitor arrangement, and lost some of my menus.  I solved this problem by switching to single-monitor, which brought the menus back. I wiggled them a little, switched back to multi-monitor, and voila! they stayed in the last place I moved them.
I'm a (recently) former ArchiCAD user.  AC had a phenomenal feature where multiple menu layouts could be saved into profiles.  Basically an interface profile manager.  It was a supremely handy feature: I was forever going between multi-screen work, single-screen work, and client presentations on a projector, and having these layouts stored saved me a ton of time.  Also helpful when I needed different sets of tools/windows for different stages of a project.
Is this the correct forum for suggesting new features?  😃
Message 26 of 47
David_W_Koch
You may want to search the Revit Ideas forum, to see if anyone has already posted a similar idea and, if so, vote for it, or, if not, create a new idea for this.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 27 of 47
Going to view>user interface> project browser did not bring up the project browser.
Other ideas?
Message 28 of 47
LisaDrago
Hello - when check the user interface is there a check in the check box next to the project browser? Can you post an image of what you are seeing? LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Message 29 of 47
Thank you so much - for how to bring back Prop. & Project Browser.
Greatly appreciated
Message 30 of 47
thank you very much !!
Message 31 of 47
Go to View tab and User Interface pull down tab and check Project browser and Properties boxes.
Laura Diamante
HAYNES + OAKLEY
HEALTHCARE ARCHITECTS
331 W. Sierra Madre Boulevard
Sierra Madre, California 91024
T 626.836.5820 F 626.836.6549
laurad@haynesandoakley.com
www.haynesandoakley.com
Message 32 of 47
Thank you so much!
Message 33 of 47
I realize this is an old thread. But I have a similar issue with revit 2014.
Half of the properties pallete keeps disappearing. I use ctrl +1 to close it and reopen it with the same issue.
The only way to resolve it is to close revit down and open it back up again. This is only a temporary fix as it will happen within 5-10 minutes of opening a new session.
Can you please advise?
Message 34 of 47
any solution for this?
Message 35 of 47
Thanks really from the heart ... you are amazing
Message 36 of 47
Right click then browsers...Then click on project browser
Message 37 of 47
This seams like the problem I've been trying to figure out for years now. However, when I go into Display Settings, my laptop is already only detecting a single monitor. There is no option to reset. Do I have to be connected to my other monitors? Any advice?
Message 38 of 47
That works . Thank you very much .
Message 39 of 47
ticking and unticking the box in user-interface doesn't change anything, any help?
Message 40 of 47
gurump
If you're losing your mind like I was and have already done the View > User Interface > toggled the palettes on and off and still can't see them....     try this...
Go to your comp's display settings > Scale and layout > change the size from recommended to something small like 100% (I'm on a 4k monitor). If that works, then change it back. I was THIS close to installing Archicad.
