Missing pipe sizing menu
4 REPLIES 4
m-de-lange
304 Views, 4 Replies
Something strange occurs for me.
When selecting pipes within a system i'm supposed to get the 'analysis' button under the tab 'piping systems'.
However, the entire button 'analysis' does not exist for me. But it does for my colleagues.
What is going on here and why can't i use the analysis button?
4 REPLIES 4
rxi.gg
in reply to: m-de-lange
Archive>Options>User Interface> Tools and analysis.
Choose what you want to see from the options you have
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
m-de-lange
in reply to: rxi.gg
I've got those turned on already
rxi.gg
route and analysis tools too?
m-de-lange
in reply to: rxi.gg
I had those turned on aswell.
It was the 'infrastructure tools' that was turned off, one below.
That was the issue indeed!
Forma Design Contest
