Missing Monolithic Stair
2 REPLIES 2
670 Views, 2 Replies
Hi all,
Did anyone have this experience? I create the monolithic stair without changing their base offset. When i try to offset from 0 to -1350, it missing but not the other type of staircase.
Can anyone help this matter?
Thank you,
2 REPLIES 2
diana.rivera.ruiz
I´ve tried in the same way like you and i have the same problem. But, when i used the tool stais - stair by sketch, put the offset in base and top if is necessary, draw first the boundary and then the risers.
I hope this help you
Regrads,
in reply to: diana.rivera.ruiz
Hi Diana,
Thank you for your response. I tried the method as per your suggestion but it still cannot be done. I just try to change the thickness of the threads and it work but not perfect.
Thank you, 🙂
