Missing logo and lines of title block family when loading to a project
Shamseera.kk73D7Q
Message 1 of 19
Shamseera.kk73D7Q
Hi...
I created a title block in Revit. but when I am loading it into any project, items are missing (horizontal line, company logo, etc.) Please see the attached image files. Where am I going wrong? I have attached the title block family also
Replies (18)
Message 2 of 19
syman2000
Solid fill in titleblock will always display as masking and hide the line. One way to get around this is to insert solid fill image.
Message 3 of 19
Try this.
Message 4 of 19
Shamseera.kk73D7Q
I tried this. but still, the company logo is missing. also while converting it into a pdf I'm not getting it in full A3 sheet.
Message 5 of 19
Shamseera.kk73D7Q
Hi..
This image option worked. Thank you. But when Im converting it to pdf, I'm not getting it in a full A3 sheet. Please see the image.
Message 6 of 19
syman2000
The extension of the reference line may cause the print to stretch beyond the A3. Try to stretch it closer to the boundary of the titleblock.
Message 7 of 19
ennujozlagam
try another PDF driver like cutePDF writer you will be able to get exact a3 size?
Message 8 of 19
handjonathan
Hi @Shamseera.kk73D7Q
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @ennujozlagam @syman2000 @ToanDN  helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
Message 9 of 19
Shamseera.kk73D7Q
Thank you soo much for helping me. The title block is working fine.
Message 10 of 19
Shamseera.kk73D7Q
The company logo when inserted to Revit title block is getting compressed and the resolution is showing as 72dpi. So the clarity is very less and its looking squished. I tried increasing the size of the logo file (.png) but no luck. What should I do? Please see the attached logo and the title block.
Message 11 of 19
Use a PDF logo and choose 600 dpi when insert it into your family.
Message 12 of 19
Try this one.  It should work.
Message 13 of 19
Shamseera.kk73D7Q
it's still the same. I can see the pixels like
Message 14 of 19
syman2000
Why not digitized the Logo into vector format? See attached
Message 15 of 19
What still the same? The logo now shows in project, but it's quality is based on your source file. If the PDF is high quality vector then you won't see the pixels at all.
Message 16 of 19
Shamseera.kk73D7Q
Thank you. This is working fine.
Message 17 of 19
Shamseera.kk73D7Q
I tried converting logo into pdf. but still I could see the pixels and also the transparent background is changing to white when converting.
but I used dwg logo file. now its working fine.
Thank you so much for helping me.
Message 18 of 19
Shamseera.kk73D7Q
How did you convert the logo(png file) to dwg format? is it a vector format?
Message 19 of 19
syman2000
I use Adobe Illustrator raster to vector
