Missing letters
9 REPLIES 9
Message 1 of 10
IN4DESIGNIDEAS
1255 Views, 9 Replies
Missing letters
While typing in anotation (text) option some symbols are missing/replaced with another. For example:
1) letter ''š'' is replaced with blank space;
2) letter ''ž'' is displayed as a '','' symbol20170606_132817.JPG20170606_132843.JPG20170606_132921.JPG20170606_133125.JPG20170606_133135.JPG
9 REPLIES 9
Message 2 of 10
screencast
Message 3 of 10
artejon
in reply to: IN4DESIGNIDEAS
A similiar issue and a resolution that might be helpful for you is described here:
https://forums.autodesk.com/t5/revit-architecture-forum/revit-2018-label-unit-symbol-issue/td-p/7100...
Revit add-ins: CAD Purger (delete UNUSED and selected line patterns & line styles, find and delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags, reuse view filter rules in schedule filters), View Filter Manager at Revit Apps Store
Tags (1)
Message 4 of 10
IN4DESIGNIDEAS
in reply to: artejon
None of the provided solutions solved my problem.
Message 5 of 10
Viveka_CD
Message 6 of 10
Hi @IN4DESIGNIDEAS
The issue is known.
Take a look at this official article.
You may also experience some issues with superscript \ subscript characters in units like m2, m3.
See this thread and this article and some workarounds.
You may check correction status in this article looking at Status field.
Rafal Gaweda
Message 7 of 10
Rafal.Gaweda
in reply to: Rafal.Gaweda
Hi @IN4DESIGNIDEAS
The issue is corrected in 2018.0.2 hotfix.
Please download and install it.
Rafal Gaweda
Message 8 of 10
Viveka_CD
Hi @IN4DESIGNIDEAS
I just wanted to follow up here, any progress on this issue?
If you find any posts that are helpful, please click on 'Accept as solution' to help others with similar questions.
Message 9 of 10
IN4DESIGNIDEAS
in reply to: Viveka_CD
Still no solution
In diferent region settings symbols display diferently, but not correct!region settings russia.PNGregion settings Latvia.PNG
Message 10 of 10
Actual solutions was simple.  The problem was in - Current language for non-Unicode programs. Only language which supports such symbols is English(United States), all others are missing them and replacing with others.
