While typing in anotation (text) option some symbols are missing/replaced with another. For example:
1) letter ''š'' is replaced with blank space;
2) letter ''ž'' is displayed as a '','' symbol
Solved by Rafal.Gaweda. Go to Solution.
A similiar issue and a resolution that might be helpful for you is described here:
Can you send us a file to troubleshoot?
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
The issue is known.
Take a look at this official article.
You may also experience some issues with superscript \ subscript characters in units like m2, m3.
See this thread and this article and some workarounds.
You may check correction status in this article looking at Status field.
I just wanted to follow up here, any progress on this issue?
If you find any posts that are helpful, please click on 'Accept as solution' to help others with similar questions.
Viveka CD
Still no solution
In diferent region settings symbols display diferently, but not correct!
Actual solutions was simple. The problem was in - Current language for non-Unicode programs. Only language which supports such symbols is English(United States), all others are missing them and replacing with others.
