Missing families
Missing families
veljy005
Missing families
veljy005
Hi!
so, I did a clear up of my laptop and uninstalled some old revit files... I think in this process I must have uninstalled something important. My revit 2023 is missing all of the basics. No mullions, no room tags, no basic doors, no basic windows. Does anyone know what I may have removed to cause this? Or how to fix it? I'm a student so not well versed in the world of revit. Thankyou in advance!
jay_colc
You don’t really need to install unless you want to work offline as you can install from the Cloud using Install Tab > Load Autodesk Family
if you do want them locally, first check the are not still on your pc and the paths are not pointing at the incorrect location.
Then if the my are not installed reinstall them for the link below (this also includes the folder locations)
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/5lnBwHsSn1OTRqm1EwYZZ5.html
Jay Colcombe
Autodesk Certified Instructor
veljy005
Thankyou so much! Life saver
