A column is not showing in any views.
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
JKspace424
301 Aufrufe, 5 Antworten
When I select the hidden elements tool  (the light bulb) I see that the column is there but I cant seem to unhide it.  What could be wrong?  I'm in the correct phase too.
5 ANTWORTEN 5
Nachricht 2 von 6
syman2000
als Antwort auf: JKspace424
Is the column place in the workset that is turned off?
Nachricht 3 von 6
JKspace424
als Antwort auf: syman2000
I dont use workset.  Where is that tool so I can turn on?
Nachricht 4 von 6
syman2000
Workset only happen if you create central model for multiple people to work in. Check the Import category and turn them on.
Nachricht 5 von 6
JKspace424
Ok.  Now I see it.  But, the column is a family under "Columns" .  Isnt imported categories for autocad drawings and such?
Nachricht 6 von 6
syman2000
Yes correct. Sometimes the family may have import CAD and it will placed CAD into the import category even if it is column.
