Missing Elevations/sections/details
I am unable to make the Elevations/sections/details visible in any floor plan. I have tried everything i know but no succes.
Knowing myself its probably something very obvious. It has something to do with the settings in the template. We have another template and there it works like it should but all the settings for the views seem the same.
I have added a project maybe someone can have a look at it. It kind of hard to make projects if i cant control Elevations/sections and details.
My thanks for any help you can give me.
Can't open your RVT file. What do you mean you can't make the Elevations/sections/details visible in any floor plan? You mean the call-outs?
MostafaElashmawy
This sometimes happens when the displine of section for example is different from the discpline of the view or when the section is set to not to show at scales coarser than ...
However, in your file, both reasons are not applicable.
Mostafa Elashmawy
MostafaElashmawy
finally I found the reason.
in your file, you have a filter for sections/Elevations/callouts
You should either remove the filter in views or check the visibility.
please check attached.
callouts
Mostafa Elashmawy
Thank you very much. Lesson learned: Do not rebuild a template you havent build yourself.
