I'm using Revit 2021 and it's the first time I have this kind of problem. In floor plans I can't see the elevation markers. I checked the crop region (it's not cropping either in the floor plans or in elevations), I verified Phases and in the elevation view and in the floor plan they are the same, I tried to change "Hide at scale coarser than "values, and nothing happened. Also in the VG it seems to be everything ok. I tried to "Find reffering views" from the project browser and they appear only in top floor, except for the south elevation, when i try the same method it appears "Impossible to find".
Can anyone help me to reveal all the elevation markers in all the floor plans please?
Thanks from Italy.
Solved by barthbradley. Go to Solution.
Does Reveal Hidden Elements (lightbulb button) show them? Is the Category turned on?
Have you gone through this list of 33?
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
It's not necessary, i checked the list (very useful, i will use it again) and i found the problem...DISCIPLINE!! in one Architectural and in the other Structural (a very stupid mistake), but thank you so much, you have been very kind!!
Try adjusting drawing scale, elevation markers can be not rendered for certain scales
