missing elements
missing elements
missing elements
hi community,
In office we've a problem with missing elements.
This elements are not in same type. They are plumbing fixtures, electrical components, architectural indoor elements.
Elements are not removed , because we find some of them.
I suspect they are hided from someone for easy work with project.
I fact i dont now exactly how many element re missing and i cant be sure they are all visible if i turn elements category 1 by 1.
Is there a way to check which element are hided nomatter category.
www.TechRoom.bg
If i understand your problem right, you can use this:
  1. On the View Control Bar, click (Reveal Hidden Elements).
    The Reveal Hidden Elements icon and the drawing area display a color border to indicate that you are in Reveal Hidden Element mode. All hidden elements display in color, and visible elements display in half-tone.
    Example
To unhide hidden elements
  1. Select the element.
  2. Do one of the following:
    • Click Modify | <Element> tabReveal Hidden Elements panel (Unhide Element) or (Unhide Category).
    • Right-click the element, and click Unhide in ViewElements or Category.
    Note: The Unhide Element and Unhide Category options become active when you select an element that was hidden by element or, a category that was hidden by category.
  3. On the View Control Bar, click to exit Reveal Hidden Elements mode.
This is official info from Autodesk knowledge base! Here's the link
This will allow you to see all hided elements (in pink). All unhided element will be shown in gray scale. The problem with this tool is very simple. When your project is big you will see all elements in same time and may hard slow your work.
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
abdi2021007
Community Visitor
Community Visitor
tidak ada element yg dihide tetapi ada beberapa element tidak muncul saat grafik dibuat relistis ataupun saat di render
