Missing colors on model lines
Hey!
I stuck... I want the color of my model lines to show, but i cannot make it.
I have tried to change visual style and detail level etc.
Thank you!
Peace, Jeppe.
Revit_Whisperer
I think we need a bit more information...but here is some basic information.
If we are talking actual lines, the color of those can be changed globally on the Manage tab, additions settings, line styles
If you are talking about modeled elements and you want to change those globally you can do that from the Manage tab, Object Styles.
Keep in mind that overrides will supersede the object style settings.
- Have you set the colors for the Line Styles?
- Are the model lines under a previous or the current Phase?
cbcarch
-Do you have Filters set up in your Views and/or View Templates?
-Check Object Styles for Lines-Overrides
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Hi. Thanks for replying that fast!
I attached a picture of my view, as you can see the model lines have no color.
Jeppe.
Are you talking about Course Fill Color (a Wall Type Property)?
...or, maybe you're talking about imported linework --  controlled via Imported Categories Tab settings in you View's Visibility and Graphics dialog box?
