MEZZITONI (=HALFTONES), what are they?
7 REPLIES 7
Message 1 of 8
f.annoscia1XRNMD
314 Views, 7 Replies
What are "halftones"=mezzitoni in Revit?
I hope "halftones" is the right translation.
Grazie.
7 REPLIES 7
Message 2 of 8
Message 3 of 8
@f.annoscia1XRNMD
Yes, Halftone the term used in the english version of Revit.
This function is a quick way to override the graphic settings of all the lines associated with the selected objects in order for them to appear lighter/thinner. It is a setting available in other places where graphic overrides are found.
Hope this helps,
-luc
Message 4 of 8
Gotta read the title and the text at the same time! 😉
Message 5 of 8
Me? Did I misread or something.  Wouldn't be the first time. Blame my aged eyes -- and brain.  😉
Message 6 of 8
Thank you! If I understand correctly, I think these "halftones" could be very useful to me when I export views in illustrator and then photoshop!
Message 7 of 8
Is this about Exporting to an Image File? Raster? I don't think Halftone will be of much benefit in that scenario.
Message 8 of 8
@barthbradley I export as a .DWG. I open it in Autocad and then I bring everything in illustrator (finally in photoshop) 🙂
Forma Design Contest
Technology Administrators
