merge two curved walls into one single wall
7 REPLIES 7
Message 1 of 8
1510 Views, 7 Replies
How can I merge two curved walls into one single wall. With a straight wall, all I have to do is pull one of the walls back and then pull it to the other wall and it will merge into one wall automatically. However, with two curved walls I cannot do that.
please see images
Would really appreciate the helps. Thanks
Tags (1)
7 REPLIES 7
Message 2 of 8
martinTstewart_Adsk
In the example you provided, assuming the curves are the same wall type, I'd delete one and extend the other to the end.
Does that work?
Martin Stewart
AEC Support Specialist
Message 3 of 8
Lance.Coffey
I am not finding a way to merge two curved walls together. I suspect that this is to protect against situations where an unbroken circle could be created.
Here is a video with more info on this topic:
As I mentioned in the video, you could post this Idea (to allow merging of curved walls) to our Ideas Page.
Lance Coffey
Technical Support Specialist
Message 4 of 8
BIMologist_
In revit the curves are treated different than straight segments. While it is easy to join straight segments , curves will not join as you are wanting. As Martin suggested to delete one and extend the other curve. Not ideal I know.
BIMologist / Dr. Revit
Approved Autodesk Services Marketplace provider - BIM Consulting
If you find this reply helpful, please use the Accept Solution or Like button below
Message 5 of 8
in reply to: martinTstewart_Adsk
Thanks for your reply
I want know if there is a possibility of merging/joining them into one
without having to delete one of them
Message 6 of 8
Your video was very informative. Thank you very much
Message 7 of 8
Thank you everyone for your input. I am a new revit user and find the community here very helpful. Thanks
Message 8 of 8
I have the same issues but for straight walls, where both have doors, so I need/prefer just to join them instead of deleting them. Any suggestion on how to do this?
