How can I merge two curved walls into one single wall. With a straight wall, all I have to do is pull one of the walls back and then pull it to the other wall and it will merge into one wall automatically. However, with two curved walls I cannot do that.
please see images
Would really appreciate the helps. Thanks
In the example you provided, assuming the curves are the same wall type, I'd delete one and extend the other to the end.
Does that work?
I am not finding a way to merge two curved walls together. I suspect that this is to protect against situations where an unbroken circle could be created.
Here is a video with more info on this topic:
